easiest way to check your rear end gear without pulling the cover looking from the rear forward;Ill try to explain this one step at a time so i dont loose you,there is a number and letters stamped on your axle housing to the right side of the chunk,not exactly ontop but just forward,if looking down the axle tube rr wheel back towards chunk around 1 o'clock 1/2 size letters and numbers,(dont give up they are really there) start scraping and wire brushing you wont rub em off,the numbers are date manufactured,in 66 your letters will be for a 1/2 ton HA = 3.73 HB= 3.07 HC=3.73 posi traction HD=4.11 JQ=411 posi Hope this helps ya
