Rear Main Seal
Discussion in '1947-1954' started by rix 48, Sep 13, 2008.
  1. rix 48
    rix 48 Member
    I'm replacing all gaskets in my 235. I've read most of the posts on replacing the rear main seal but not really sure I understand the part of "curl the top piece over the bearing":confused:
    I'll be using the neoprene seal and I have the oil pan, bell housing and flywheel off. Should it be fairly straight forward???
    Also, what size are the freeze plugs?
    Thanks,
    Rick
    Late 235 right ? .
    If it has a rope seal , you've gotta replace it with the same typ , a special tool called a " Sneaky pete " that looks like a chinese finger trap grabs old of one end and wraps up and over the upper main bearing , pulls it into place slicker 'N greased snot .
    Getting the old one out can be tricky , DON'T nick the polished bearing journal ! .
    The rubber typ seal , work at it and when you're ready to give up , it'll slip right out into your hand .
    This has been covered in excruciating details before , I don't have the time right now to repeat it .
    Freeze plugs , I know you've been asking , I always knock 'em out and slip int my pocket and go hunting for brass ones ~ you don't want to waste all that effort on steel Welsh plugs ! :rolleyes:
  3. rix 48
    rix 48 Member
    Thanks Nate
    Heck, I thought you were going to tell me it's easy...go for it! I'm not sure what is in there right now so I guess that's the next step.:eek:
    Rick
    Well ;
    I did my first one as a teenager with little experiance , as it's an ' In The Car ' typ of repair , I'd consider it easy .
    Working on old farm trucks that only decided to repair after it'd been leaking for 20 years , well , that's not fun due to the amount of crud glued to the entire underside of the truck with leaked out oil ~ I always loosen up the meain bearing caps ,as this drops the crank a tiny bit but that little bit extra really helps .
    For all I know , there's now a <magic> modern design neoprene seal to replace the old rope typ one ~ were I @ work I'd peek in my Victor Gasket Catalog to see although it's a 20 year old book and so maybe not up to date .
    I used something thin and flexible , worked it behind the rope to loosen it then it slid right out with the Snbeaky Pete , I soaked the new one in oil overnight before installing , yoiu need to ensure it's stuffed all the way deep into the groove and I leave a little bit un trimmed sticking out so when the rear main bearing cap is torqued up it makes a good seal at the joint ~ I've been told this is not good practice but it works for me .
