Resistor Help?
Discussion in '1967-1972' started by hatericeburners, Sep 16, 2004.
  1. I have seen this picture that says the factory engine harness had a voltage resistor that was designed to limit the points type distributor to only 6 volts. I got the truck already with the up-grade to HEI. But, I have no idea if he eliminated the resistor to allow the new distributor the full 12 volts.
    I have limited knowledge, but it confused me. I belive the caption speaks of the resistor wire but the picture (included) confussed me.
    help a college freshman out.
    Thanks a bunch.
    Tony from USF
    https://talk.classicparts.com/images/attachments/CDocuments and SettingsAnthony FordDesktopchevy.wpd
  2. tech1
    tech1 Member
    RE: the photo
    i would imagine that he took it off because if it was still on 6 volts it would not run good at all.
  3. RE: the photo
    thanks tech 1
