psy999
I have a rochester b carb with manual choke that I rebuilt recently for a 1954 235 (still stumbles on accel with weak power, works good with choke slightly on). I could continue to tinker with the carb to see if I could fix it, but instead I just bought a rochester b carb with manual from Chevy Duty. I wanted to see if the pro rebuilt would work better before I completely gave up on rochesters.
Unfortunately, I can see no way to hook up the choke cable on the chevy duty carb, even with taking accessories off my existing carb. I've included a picture of the linkage on both carbs, and used a small white arrow to indicate the direction the linkage must go to activate the choke. As you can see on my old carb, there is a "cable stop" (for want of a better word) to attach the choke cable to the linkage. There's no such thing on the rebuilt.
Of course this happened on Sunday when tech support wasn't available. I called today and got an answering machine. I left a message but don't see how this will work with my busy work schedule.
Anyone come across this problem and have a fix?
P.S., Nate, you mentioned that Chevy Duty had their rochesters rebuilt by Carter. The box says Champion, is this the same as Carter?
Thanks
Dave
Thanks
Dave
