Rochester carburetors
Discussion in '1947-1954' started by Guest5979, Jun 6, 2020.
  1. Guest5979
    Guest5979 Guest
    I have 2 Rochester carburetors both have been rebuilt sometime back one is on the truck now and works great btw 235 engine
    Do I have to do anything different in order to put both of them on a Fenton duel intake manifold?
    Will I notice any improvement in performance with duel carbs ?
    I have Fenton headers and a pertronix ignition that will be installed before end of this summer.
    Thanks for any feedback
  2. RidesWithYah
    RidesWithYah Member
    Lexington KY
    I haven't done this yet but looked into it... From what I've read, a pair of 235 carbs end up "too big". Folks recommend a pair of 216 carbs; or Tom Langdon sells a small carb that's supposed to be great for this type of setup. Whatever you decide, make sure they are jetted *exactly* alike. And I hear choke is only needed on one.
    Store - Langdon's Stovebolt
  3. Guest5979
    Guest5979 Guest
    I do believe they are jetted the same only difference I had seen in them was when one was on the 216 engine was the base of the carburetor when I swapped to the 235 I just changed the carburetor base for a 235 base.
  4. Guest5979
    Guest5979 Guest
  5. Guest5979
    Guest5979 Guest
    Are these the only two gaskets needed for a Fenton duel carburetor intake manifold?
    Thick insulator on manifold and thin gasket between carburetor and thick insulator?
  6. Guest5979
    Guest5979 Guest
    I’m looking for a 1 barrel Rochester carburetor base for a 235 engine
    If anyone has a core carb please let me know.
    Thanks
  7. vwnate1
    Lotta disinformation on dual carbys .
    You need two identically jettedcarbys, 'B' series Rochesters are fine .
    You'll need to balance them, this is the tricky part ~ be sure to have a separate return spring on each one, the spring must be very gentle ~ no big beefy thing .
    Disconnect the linkage between the two carbys and warm up the engine then use a uni - syn device or other manometer to get both carbys to pull the *excact* same vacuum at idle then adjust the idle speed to 500 ~ 1,000 RPM then re attach the linkage .
    Of course, you'll need to begin by ensuring the valves are bang spot on and the ignition timing is perfectly set to ball on pointer or you'll be chasing your tail forever .
    Don't be shy to ask for help repeatedly ~ those who know this can do it fairly easily .
    I used to do it by ear before my hearing went .
    Yes, more power, and better idle along with better fuel economy *if* you can resist using all that extra power....
