Rod Cap
Discussion in '1947-1954' started by willardgreen, Oct 19, 2009.
  1. willardgreen
    willardgreen Member
    Dixieland!
    Looks like a rod cap gave way today. Wonder how hard it is to balance a 235? I think I can balance rods and pistons but not the crank. IMHO a balanced 216/235 is the most admirable old engine there is. You have to look at the fan to see if they are running. This has been a slim year for money and thats no Pelosi:(
  2. coilover
    Doggone it Willard, I just gave away a brand new, never been started 235. The man that bought the truck from an estate wanted a V8 with all the bells and whistles and another fellow at the VW restoration shop just down the road has an old AD he's tinkering with so bye-bye 235. Normally shipping is too high so I don't mention pull out engines but it sounds like your not a great distance away. I have a 37 engine out of a farm truck with 41k miles but it has cast iron pistons, a different front plate, and several other things that would be like backing up from a 50's engine. A contributor on this site, "cimberdad", called my engine builder and he quoted him $550 for a short block completely rebuilt. A very good price but five hundred bucks more than I would have charged you for that take out. Don't dispair and find out who does street rod work in your area. Perfectly good inliners get pulled frequently. If you lost a rod cap most likely the crank got gouged and won't grind.
  3. ol' chebby
    Where are you willard?
  4. willardgreen
    willardgreen Member
    Dixieland!
    Meridian Mississippi.
  5. willardgreen
    willardgreen Member
    Dixieland!
    Thanks for empathy!
    My first car was a 62 bubble top Bel Air with a 235. I felt sorry for myself and replaced it with a 300-HP 327. I never realized how great a 235 was untill I bought this truck for my son/me too. Never a problem in ~4,000 miles, oil pressure gague was always maxed out. Got oil all over the place adjusting valves, then sudden death. A lot like a friend dieing. At least engines can be bought. Anyone have high opinions of hydraulic valves? I like quite;) Probably gonna take a gob of money juice. Hope next year is better.
  6. vwnate1
    235 Fun
    Willard ;
    Hydraulic lifters are a wa$te of time & $ on these engines , they rob power and will ALWAYS clatter @ hot idle .
    If you can find an honest racing machine shop (good luck) yes , you can balance the engine including the crankshaft , flywheel and clutch cover plus the rods & pistons , all to ZERO grams and the boost in tractible power will be amazing plus you'll be able to smoothly crusie down the freeway without worry it'll blow up .
    Adding a 261 cam will increase power and fuel economy too .
    Having the exhaust ports in the cylinder head smoothed up and the exhaust valve guides un shrouded wil increase power end reduce operating temperatures , a win - win situation but DO NOT port it nor do anything to the intake ports other than having them matched to your intake manifold ! .
    Don't replace that old oil pump if it was working well , the new Melling pumps tend to be junk , low pressure and volume .
    I have written reams of detailed 235 hop up info before , it's in the archives , money well spent .
