RUST
Discussion in '1947-1954' started by Bill Hanlon, Apr 18, 2017.
  1. Bill Hanlon
    What can I spray on metal parts to prevent rust for years of storage? Things like oil pumps, rocker arms, flywheels, heads, etc?
  2. 52wasp
    52wasp Member
    Wilton, New Hampshire
    Bill,
    1. Fogging oil in the spray can
    2. motorcycle chain lube, also in a spray can- it has high "cling" strength.
    3. plain old rustproofing, diluted with wax-and-tar remover, and sprayed.
    All will be messy on an exterior surface.
  3. Bill Hanlon
    Think I'll try the chain lube.
  4. 52wasp
    52wasp Member
    If you do try the chain lube, change out the spray tip for a wide-fan style. The one that comes on the can is a narrow fan (so you only lube the chain and not the entire motorcycle).
  5. Depoebay
    Depoebay Member
    corrosion x HD. good stuff
  6. Lakeroadster
    Lakeroadster Member
    Central Colorado
  7. cantdrivemall
    cantdrivemall Member
    Calif.
    I also go for the GIBBS.
    Wipe your chrome down with it and not worry about rust or corrosion for a couple years. GREAT STUFF! Gunsmiths swear by it
