I purchased a 60/40 seat out of a 93 chevy. Short term I want to put the seat in now. I will eventually move the fuel tank to the rear. My question is, how much am I gaining by taking the tank out? Is it worth even putting the new seat in with the fuel tank in the cab? I'm 6'3". Thanks for the help.
A lot depends on how thick the seat back rest is, with the tank out I only gained two inches at the base of the seat, with the back rest straight up ...`05 silverado buckets....I`m only 5`8`` so no issues....
In regards to leg room you gain nearly nothing by removing the gas tank from the cab. That's because, as Rich eluded to, the seat back needs to recline to be comfortable. Therefore the top of the seat will hit the back of the cab before it hits the gas tank. GM did their homework when they designed the seat and the back of the cab to ensure the most leg room available. You do gain valuable in cab storage space by removing the tank though. I removed mine and am glad I did. I hope that helps. John
Leg Room John Wrote : "GM did their homework when they designed the seat and the back of the cab to ensure the most leg room available." THIS ! . Of course , although I'm 6' tall (lost 1" over the years) my inseam is only 3" so I fit almost anything easily . Some of us older guys have a bit of , uh " girth " that rubs the steering wheel so that's always a concern .
All good information. Think I'm going to go ahead and mount it with the tank in for now. When I get to my full restoration I will pull the tank out. Thanks again.
