Sending unit Ohms
Discussion in '1960-1966' started by 66longbed, May 7, 2012.
  1. 66longbed
    66longbed Member
    Lake Havasu City, AZ
    Anyone know the Ohms rating on a 66 fuel tank sending unit?
  2. my2ndgirl
    my2ndgirl Member
    Hickory NC
    ohm's for a 66 is 0-30
  3. Lakeroadster
    Lakeroadster Member
    Central Colorado
  4. Rich 5150 69
    Rich 5150 69 Member
    Nor Cal
    If the gauge is original to the truck the sending unit should be 90 ohmns, GM changed to 90 ohns for that year, `65 and ealier were 30 ohmns, when the exact date was in `65 late model year I don`t know.
  5. 66longbed
    66longbed Member
    Thanks for your help guys
  6. my2ndgirl
    my2ndgirl Member
    Hickory NC
    all I can tell ya is what mine
    was..30
  7. dcsi5919
    dcsi5919 Member
    Kansas City United States
    Put a multi-meter on it and see.
  8. my2ndgirl
    my2ndgirl Member
    Hickory NC
    well I've relocated my tank and replaced the gauge with an auto meter 30ohm...works awesome!
  9. Lakeroadster
    Lakeroadster Member
    Central Colorado
    I have an Autometer 0-30 ohm gauge in my truck also. What did the relocated gas tank you are using come out of?
  10. vwnate1
    Relocated Fuel Tanks
    I've been looking at rear mounted , behind the rear axle & between the frame rail tanks for many years using Brand "F" Econoline tanks , Sunday I was looking at a nice bagged 1960 3100 and he used an old IHC Scout tank , it's compact and was easy to mount in front of the rear end , between the frame rails , using the Scout's tank straps . he said the sender worked with the Chevy fuel gauge too .
  11. my2ndgirl
    my2ndgirl Member
    Hickory NC
    I used the tank kit from a local supplier..same one our host offers. Worked good bolted right to the frame rails. I believe it's the suburban tank.
  12. Lakeroadster
    Lakeroadster Member
    Central Colorado
    Is it the extra capacity tank? Got any photo's? The tank I bought for the back of my truck didn't have a sending unit so I bought one from Brothers. Did your tank have the sending unit included?
  13. my2ndgirl
    my2ndgirl Member
    Hickory NC
    sorry I don't have any pics...but yeah it came with a sending unit. Had to cut the neck off about an inch, plug a couple of vent holes..except the main vent.
    Capacity is 20 gallons...and it doesn't go below the pumpkin...it's actually about 3 inches above rear end. I'll try to post pics...I have any much luck posting on here...I know I have a pic in my phone
