Good day all; I have a 69 GMC I am working on. I have a Borg Warner Super T 10 4 Speed and # 1304-065-903, # Behind reverse is 11-04-966=901. Date code 12-15-75. 2 splines on frot shaft with 2.40 gear. I also have a Hurst shifter # 301-7879, with no linkage or mounting bracket. Question, What shifter, or linkage kit do I need for this tranny to work properly in the truck?
You might try going to the Jegs or Summit websites and see if you can match up your combination. Probably your best bet is to get the information right from the horses mouth, so to say. I would contact Hurst Performance Products: (818) 483-1366. I called them when I was trying to determine what kit I needed for my M-21 Muncie / Hurst Shifter set-up, they were very helpful and gave me the correct part number information.
