Shimming a 3.55 ring and pinion
Discussion in '1947-1954' started by dan cocomise, Feb 19, 2013.
  1. dan cocomise
    dan cocomise Member
    I am swapping 4.11 for 3.55 ring and pinion on 1948 1/2 ton.I need some shim help the original shims where .033 any idea where to start the new shims at.Thanks
  2. Blueflame236
    Blueflame236 Member
    Norway
    Shims crown & pinion !
    This is old school work. There has to be an excact clearance at both sides to let both the crown & pinion work together with the spider gears. They normally use blue lackmoose paper on the gears to get a good measure. You could make a phonecall to Patricks and ask him over the phone as the manual he has about this swap is not of a good quality.
    This manual is on the subject ;http://chevy.oldcarmanualproject.com/shop/1948_51truck/51ctsm0409.htm
    In case you dont sucseed you could ask a local mechanic to assist as this has to be very presizely done.
    http://www.patricksantiquecars.com/
    Good luck Martinius.
