side fender spare tire mount 55
Discussion in '1955-1959' started by srvtexas, Oct 12, 2011.
  1. srvtexas
    srvtexas Member
    New to the forum. I need help in getting a proper mount for the fender well spare tire. All I have now is a hole in the bed frame that is surrounded by metal that seems to thin to support a tire. I know this has most likely been talked about before but I cant seems to find the answer I need. Thanks in advance for any help.
  2. AZ58Cameo
    AZ58Cameo Member
    Payson Arizona
    Do You Have The Spare Tire Bracket That Bolts to the Bed and Fender?
    Sounds Like Your Half Way There, In that You Need the Rest of The Parts To Complete the Spare Tire Mount!
  3. srvtexas
    srvtexas Member
    I do not have anything. i have seen a few bracket on-line. The recess in the left fenderwell has a hole that looks like it held the original bracket. Does anyone have a link to a website where i might buy one or maybe a diagram of how get one fabricated. The only on I saw online so far required holes in the top of the bed frame which I really dont want to do.
  4. AZ58Cameo
    AZ58Cameo Member
    Payson Arizona
    I Have Had One But It was On a Parts Truck I Had But I do Remember
    It was Very Ridged and The Brackets Bolt To The Bed and there was
    a Bracket That Bolted to the front Head Board.
    I am Sure Some One Can Post a Picture Of There's And Show You The Full
    Assembly, I Know I have seen Picture's In the assembly Manual,you Might Try To Find a Book Or Salvage Yard to Find One. Pretty Sure That Bracket was made Past 59 and Into the 60's Model Trucks Also.Allot Of Truck Builders
    Including Myself, Opt Not to Go With the Spare Tire and Want The Cleaner
    If You Will Look, So I Think You Would Be able To Find pretty Easy.
    I Sold mine On Line To a Guy So I Would Ask Around !
    Allen
  5. srvtexas
    srvtexas Member
    fender
    Thank You for responding. The guy who I bought the truck from said he had the full fender if I wanted it. That may be easier and better looking. Thanks again. I'll post pictures later.
  6. Lakeroadster
    Lakeroadster Member
    Central Colorado
    First or second generation 55?
    If it's a second generation the hole in the fender is just a clearance hole. Any of these 2nd gen. photos help? (FYI: not pictures of my truck)
  7. trucktony
    trucktony Member
    The Netherlands
  8. trucktony
    trucktony Member
    The Netherlands
    I made few from some thicker iron bars
    So I could be sure of the weight the have to carry.
    I kept the upper bars off of the construction so I could level them with the holes I had to make on the bed rails.
    My example had the upper arms cut off, so i could not copie them.
    I hope this will solve your problem
  9. srvtexas
    srvtexas Member
    problem solved
    Thanks to everyone here for your comments and help. Found a mount and am having it shipped to me this week. Thanks again! :D
  10. McTools
    McTools Member
    Where did you find the tire mount? I've had problems looking for the same part...
  11. Ryan
    Ryan Member
    My uncle is looking to fabricate/purchase a side spare mount for a 57 GMC 3/4 ton.
    This link is very close to what we are looking for, but the 57 model doesn’t have the eyelet hole in the side panel for the rod to travel through. Any chance you have the plans for the frame that fits this model?
    http://www.stovebolt.com/techtips/sparetire/mount_fabrication.html
    Thank you!
