I have a 8 prong plug on my tilt GM column (Delco Remy plug 08 67) and need to wire into the 1957 Wiring Harness ......anbody have a clue what goes where ? Or if I can find the diagram for the column plug I have now? Thanks Shawn
I don't have a diagram of the stock plug, but I do know the color codes from it. Light Blue - to LF turn lamp Yellow - from flasher Dark Blue - to RF turn lamp Pink - to LR turn/brake lamp White - from brake switch Violet - to RR turn/brake lamp
Thanks Bill Any idea what the wires are that come out of my later model GM steering column ? It has an 8 wire plug......delco remy ...the plug is radius shaped , so I need to see if I can get the proper end from CPofA and do some splicing !! Took the truck on its maiden voyage on Sat .........its been 15 long years since I last drove her! Went 2 blocks to the Legions cars show ..... I think power steering is in my future ! Shawn
Chris,,,, You Rock ! Thats exactly what I needed to hook up my column wire to the harness I bought !! I pigtailed each wire to trial the lights and it worked perfectly ........ Thanks !! Should be on the road within the next week or so !! Shawn
