Single belt
Discussion in '1947-1954' started by Guest5979, May 5, 2018.
  1. Guest5979
    Guest5979 Guest
    FCD3C47B-13F1-4D07-A716-273086838F99.jpeg FCD3C47B-13F1-4D07-A716-273086838F99.jpeg EEBAD08D-FF02-461C-9B46-26D3970DDE71.jpeg 0C61E9C0-2A28-4A9B-8A64-21A0A2384C49.jpeg EEBAD08D-FF02-461C-9B46-26D3970DDE71.jpeg F54F7614-D5C5-4E90-B319-EAA52A174DC1.jpeg 0D8BCCDF-505E-4A16-A60A-F40CFEA968CD.jpeg B76356E4-F078-43F9-A31A-007D72E57DD0.jpeg
    Neto84 likes this.
  2. Guest5979
    Guest5979 Guest
    Is it possible it get enough tension for a single belt?
    Figuring out a bracket for a Power steering pump and bracket for my 235
    Thanks
  3. 52wasp
    52wasp Member
    Wilton, New Hampshire
    I'd say it's as much wrap as it is tension. Too much tension eats up the bearings, hence all the idlers on today's serpentine setups- you get all the wrap you need, and one spring-loaded tensioner to keep the whole deal snug.
  4. coilover
    I have run a single belt on my 37 Buick straight eight for over 30 years with no problem and it has an a/c compressor where you have a p/s pump. The compressor puts way more drag on a belt than does the pump. I was concerned by just 45* of belt wrap on the water pump so I put an electric fan on it those many years ago with the idea that since a fan is a bigger draw than the pump I could do away with the fan blade if needed. It was a baseless worry and I haven't had the fan on from the day it was installed. The Buick looks just like a 235 with two less cylinders.
    Neto84 likes this.
  5. Guest5979
    Guest5979 Guest
    Thanks for the pics Evan
    I’m going to look for a 2 belt pulley for the alternator next weekend.
  6. wolffcub
    wolffcub Member
    Setup i made using a double power steering pulley.
    Neto84 and Zig like this.
  7. Guest5979
    Guest5979 Guest
    Thanks for the pics will run that route if I can’t find a double pulley to fit my alternator.
  8. Zig
    That is an awesome setup and I love all the chrome!
    Should I ever feel the need to add AC, I will go this route!
    ...Maybe even add chrome too... #cool#
  9. Bill Hanlon
    That is how my truck is except a dual belt pulley on an A/C compressor instead of a power steering pump.
    Zig likes this.
  10. Guest5979
    Guest5979 Guest
    Engine is a piece of jewelry
    Did you make your own brackets?
