[updated:LAST EDITED ON Jul-04-02 AT 05:01 PM (CST)]x( I know you can adjust the doors on the 1963 in or out where the hinge bolts up to the door.Can you adjust the door where the hinge bolts to the cab? What i really need to adjust is the striker plate on the rear of the door jam.But its unadjustable.The rotory latch in the door clicks into both lock posistions,but when you pull on the door,theres a half inch of slop,like the striker plate needs to move inward toward the seat.All the seals are good.(but not sealed)The hinges are not wallard out.All the door-to-cab body lines are even and match up.When the door is closed,(both clicks)the lines match up,but you can still push the door in one half inch.(then its sealed)The hinges dont LOOK bent.Any ideas? Boondawg@alaska.com
