Sloppy Steering - '57
Discussion in 'Classic Parts of America Talk' started by samsimone52, Sep 4, 2010.
  1. samsimone52
    samsimone52 Member
    The steering on my 1957 straight axle truck is getting sloppier all the time. I have power steering, and between the two, I'm all over the road. Will new kingpins and bushings mostly correct this?
    Wandering
    Yes but ;
    You must remove the play from ALL the suspension bits ~ tie rod ends , wheel bearings , even the sping bushings have much to do with it ~ when the rear spring bushings get loose , the resulting 1/8" of side ways rear end movement , reverse steers the front of the whole truck like crazy .
    Each tiny bit of play , ads up .
