The 59 235 for my 50 is back from the machine shop and is going back together. The manual gives me hot valve clearance numbers. I would like to know cold numbers to get me in the ballpark. Thanks
Initial Valve Adjustment Same thing ,use .020" on the exhausts . Just re-check and adjust them as needed once you've broken it in . For Max. performance you can run the intake gaps down to .010" .
