Spedo gear
Discussion in '1947-1954' started by ronaldg, Mar 6, 2011.
  1. ronaldg
    ronaldg Member
    I changed my rearend from 4-11s to 3-55 from patricks and it works great problem is my spedo was about 20 miles slower than actual speed then it finely snapped so i now need to replace the spedo cable and i orderd this gear form patricks its a gear that will give me the right reading on the spedo that attaches to the end of the cable at the transmission well ive been waiting almost 2 months for the gear mind you patricks is having a problem with his supplier and I understand that, question is does any body know where else i can aquire one of these gears I need one soon because i am going on vacation with my truck soon thanks for any help.
  2. smfulle
    smfulle Member
    Ogden, Utah
  3. ronaldg
    ronaldg Member
    spedo gears
    Thanks stan ill give them jinble.
  4. Kens 50 PU
    Ron, I'm embarrassed!
    I guess I should have read your question more thoroughly the other day! All I saw was "speedo" gear and vacation! For a minute I thought you were asking about where to get speedo swim ware to take with you on on vacation!:eek::eek::D:D:eek::eek:
    Just funning you!
    Ken:D
  5. ronaldg
    ronaldg Member
    spedo
    You do not want to see me in a spedo trust me
  6. coilover
    You can go to www.bowtieoverdrives.com and click on calculate speedometer gears for either the 700 or 200 OD trans. I just measure the tire diameter and plug that in along with the rear gear ratio rather than try to put in all the aspect ratio mumble jumble. It will give you the tooth count on the drive gear on the trans output shaft and the count on the driven gear on the end of the speedo cable. You can then get them from any GM dealer---not just Chevrolet.
  7. ronaldg
    ronaldg Member
    speedo gears
    Thanks for the link Evan I check it out
