Speedo / Cluster Question and Recommenation
Discussion in '1947-1954' started by cmkruse, Oct 11, 2014.
  1. cmkruse
    cmkruse Member
    SUNNY FLORIDA
    I need a little help and a recommendation. I'm doing my cluster and speedo. I have an original speedo manual that cover several types. The breakdown show two gaskets - one on each side of the glass. Do the AD types get two gaskets of just the one between the outer bezel and the glass?
    Secondly I was reading the tech article from the stovebolt site I think and it indicates the use of decals but show a kit that looks like to me to be the adhesive backed vinyl type. So who sells the best kit? Decal or Vinyl?
    Thanks for chiming in.
    __________________
    Forum friends thanks for all the help - past and present!
    Craig / 49 Panel
  2. ol' chebby
    The vinyl decals are all I have been able to find. They work wel, just make shure the under surface is clean and smooth.
  3. cmkruse
    cmkruse Member
    SUNNY FLORIDA
    Cluster F**k
    I used one set of the vinyl ones and the speedometer decal doesn't stick real well due to the step or raised area next to the needle area. I tried pricking (old trick for letting trapped air out of decals) the vinyl with a pin to let the air out next to the step but that didn't work. I guess I'll have to live with it and hope it doesn't bubble up come summer time. :(
