Speedo Gear
Discussion in '1947-1954' started by doug49, Sep 2, 2013.
  1. doug49
    doug49 Member
    In my 49 Chevy pickup I changed rear gears from 4.11 to 3.55. I understand there is a adapter that I can install in the speedometer cable to indicate the correct speed. Where can I buy one and how is it installed?
  2. Bill Hanlon
    Morris Ranch TX
    Google "speedometer ratio adapter" and you'll find a bunch of them. Most screw into your tranny and then the old cable screws into the adapter. You'll need to specify the old and new rear-end ratios. Also, if you have made a drastic change in rear wheel diameter be sure to take that into consideration.
  3. Blueflame236
    Blueflame236 Member
    Norway
    Gearbox ?
    What kinda gearbox do you have 3-4 gir , Saginaw or Muncie ?
    Martinius.
