speedometer swap
Discussion in '1973-1987' started by 85scottsdale, Jul 4, 2005.
  1. 85scottsdale
    85scottsdale Member
    little chute
    is it possible to take a speedometer from like a 73ish chevy or the meters that went to 100mph and put it in my 85 c10... would it read correct?
    ________
    Problems With Zoloft
  2. 73_79Chevy350
    73_79Chevy350 Member
    racine usa
    i have also played with swapping gages out of the era trucks you
    can do it but you have to watch what you have vrs what you want I.E. oil presure as for the speedometer i believe it should work correctly. Its been a few years since ive done it and never paid too much attion to it ( never went by a speed trap trailer to calculate) find out if the speedometer is calibrated itself. hope that helped (at least alittle)73-79chevy350
  3. Pontiac1976
    Pontiac1976 Member
    Ontario, Canada
    if full gauges
    yes you can swap out the speedos but some may read in K/m after 81 in the usa or if it's from canada and has 7 digits it K/m if it's 6 it's in Miles.
    same goes for the oil gauges in PSI or KPA water temp is another F or C
    BUT AMP and VOLTS are not inner changeable unless you do dash and fuse wiring because "fire if you plug and play with these"73-75 AMPs, 76-87 VOLTs. 73-80 mechanical oil pressure, 81-87 electric oil pressure.
    oh 81-87 plastic neddles 73-80 alum. neddles
  4. tech1
    tech1 Member
    speedo swap
    You can switch the speedos, the needles my be a different color, but thats it. If you have problems calibrating the speedo you will need to change the small plastic gear where the speedo cable goes into the transmission.
  5. Old77
    Old77 Member
    Lee's Summit
    You should just do like I did and take out the gauges completely and put in Dakota Digitals! They look killer at night!!!! Well worth the high cost.
  6. 77 Chevy
    77 Chevy Member
    Mission, KS
    Hey Old77 do you have any pictures of the Dakota Digital gauges installed at night?
  7. redbeast
    redbeast Member
    I'm not sure about the speedometer gauges, but the fuel gauges will not indicate correctly if it's a few years off. 1/2 tank indication = empty tank on mine.
  8. Old77
    Old77 Member
    Lee's Summit
    Here's a picture of them in right after I got the dash done before i put the carpet in the truck. You can kind of see them on but with the angle it's somewhat hard to tell. I don't have any at night yet but you can imagine how cool it is from this picture. :)
  9. Pontiac1976
    Pontiac1976 Member
    Ontario, Canada
    Ok if you change the gas you should make sure the gas is the same size takeas you had,
    But the Gas gauge should not mater, " because the sending unit would be the problem different size tanks different sending units " or bad gauge, bad ground, bad leads, bad + connection gauge.
