Starter Motor wiring different?
Discussion in '1947-1954' started by Flashlight, Jun 12, 2011.
  1. Flashlight
    Flashlight Member
    Remember way back 8-9 months ago? I had this miss in the 62' 235 motor that defied solution. It was a badly worn cam, worst case scenario, huh:mad:.
    I have a spare 55' motor that started right up. My truck has got a 3 wire harness for the 62' starter. The 55' starter has only two wires. I want to keep the parts from each motor with each. Is there a way to use the 2 wire starter with my 3 wire harness?:confused:
    BTW, I found a NOS 54' Corvette 235 cam, I hope it will be OK in the 62' motor. It is being rebuilt by a good shop, and I will again have a fresh spare 235. :rolleyes:
    So Then ,,,,
    Use the '55 starter on the '62 235 engine .
  3. Flashlight
    Flashlight Member
    No Way to Macgyver these starters?
    Thanks Nate, I was going to do that, not because its electrically correct. Rather, I am too cheap to buy another one:rolleyes:. I just wondered if there was something I missed or could change the wiring to get the two wire to go.
    Naturally I did not count the flywheel teeth and have some concerns there. I used the smaller 55' sedan clutch and pressure plate and the 62' had a larger clutch and pressure plate, I assumed was truck size. Hopefully the starter motors will engage the same way on either one:confused:
    Flashlight
    12 Volt Starters
    Pretty much all interchange .
    The ring gear tooth count remains the same regardless of the clutch diameter .
    DO take the opportunity to take it carefully apart and clean & grease it .
