Starter ?
Discussion in '1947-1954' started by graham, Oct 8, 2012.
  1. graham
    graham Member
    Houston Texas
    Some times when I hit the foot starter it will turn over for a couple seconds before it stop spinning the motor. But then other times it will spin the motor over until I let off the starter. The teeth on the fly wheel and starter are good. Could it be a bad starter?
    Cranky Starter
    It's prolly old and filthy inside with badly worn brushes~ take it off and apart , look at the mess and *gently* clean it all up , replace the brushes (there's four) with good quality ones from NAPA and grease the bushings lightly before buttoning it back up .
    If it's still wonky , you only $pent $10 , take it to your Auto Electric Shop and they'll square it away .
  3. Kens 50 PU
    It too could be faulty contacts in your starter switch or faulty ground wire also. Take the time to touble shoot!
  4. Coach529
    Coach529 Member
    Jamestown, ND
    Try pushing the button on the starter to see how that responds.
