steering linkage
Discussion in '1947-1954' started by nikalos, Nov 6, 2010.
  1. nikalos
    nikalos Member
    can someone let me know what size the shaft is on the mustang ll rack and pinion to hook up to a linkage
  2. coilover
    I can measure one tomorrow but most just order a U-joint or rag joint from Borgeson, Flaming River, or other suppliers. The joint will be splined for the Pinto/MII on one end and for a double "D" shaft on the other. The very early Pintos had a smaller shaft so the suppliers always go by spline count rather than just shaft size. If your mating to certain GM columns they take a 1" double D while most all others are 3/4" or you can use a round shaft and just mill (or grind) flat spots on it.
  3. ol' chebby
    It is 3/4" splined shft, 26 splines, I think, but may be wrong.
