Stock rear brake pedal
Coach529
Oct 2, 2012
585
17
Age
52
Location
Jamestown, ND
Website
kustomcreations.smugmug.com
I am using the stock rear brake pedal on my 49 with an upgraded master cylinder, prop valve and disc brakes in the front.
I was sitting in "Henry" tonight and wondering why the damn brake pedal has to sit so far off the floor. It is about 9-1/2" off the floor. It sure would be alot easier to go between throttle and brake with the pedal closer to the floor.
Has anybody ever shortened the throw?
You'll get use to it, trust me. It's interactive driving at it's finest!
You already bought your goodies, but I think the firewall mounted mc's might allow for what your wanting.
Coach, yes I have done it. As my wife is also driving the truck, i wanted her
to feel as comfortable and safe as possible.
I also added disk brakes at the front and a power assisted mc, so i thought
there wouldn´t be a problem, to take out about 3 or 4 inches off the pedal.
Just welded back the plate and it was a total different(better) feeling.
Hope this helps:)
Hope this helps:)
Great info.....thanks!!
I remember reading (don't know where) that the firewall needs reinforcing if you mount the MC there. I hope someone can confirm or refute this info - just want everyone to be safe.
M/C Mount
Only if you want to be SAFE ~ others will take the chance of a firey death :eek: .
That's the least of the problems for me~
I cringe at the thought of having to get back up under the dash for ANYTHING~ let alone trying to work in the reinforcement needed for this operation. I once considered doing this, but that was then...
For me with huck brakes I like that extra travel. My peddle is high and tight! The farther away from the floor the better;)
Brake Pedal Height
Although Huck (rhymes with SUCK) brakes you need it else you'll die :eek: ,
A high brake pedal is also a good thing on any working rig and certainly anything with drum brakes no matter how well you maintain it .
The MC's pushrod freeplay can be critical and should always rattle if you shake it by hand , else it's too tight .
More than once I've over driven some old rigs brakes until the harder I pushed , the faster it went , once the brake pedal begins touching the toe board , you're in deep doo-doo .
Still and all , most of my oldies all run original drum brakes albeit carefully maintained and adjusted .
The Met's tiny , toy looking dual leading shoe front brakes only last 6,000 miles or so before I have to reline the shoes ~ they stop much better than you'd think but I don't think BMC was figuring me or anyone else routinely driving it 70 MPH down twisty canyons with Sports Cars...... :D .
I keep breaking off front wheels too , I may try some vintage Dunlop alloy wheels I recently found , they're nice but I like steelies and stock chrome hubcaps .
