Suggestions on Headers
Discussion in '1955-1959' started by steve, Dec 31, 2009.
  1. steve
    steve Member
    Virginia
    Anyone have sugestions for exhaust headers? Ones that fit a 350 Chevy engine in a 59 Apache with a stock frame? Shorties vs full tube, block hugers and brands that hold up?
    My son's birthday is 01/01/85, we spend the day working on my 1959 removing motor and transmission. Then had lunch as a family unit. :D
  2. I.F. 59 Apache
    I.F. 59 Apache Member
    Idaho Falls, Idaho
    I am looking for headers too. I put in a search on Summit's site and they have quite the selection. It just depends on how much $ you want to spend.
  3. steve
    steve Member
    Virginia
  4. I.F. 59 Apache
    Idaho Falls, Idaho
    I would be interested to know how well they work with the stock stearing box. Let me know when you find out.
  5. Bobby 57
    Bobby 57 Member
    Long Beach Ca
    I'm rebuilding 57 1/2 ton with a 350 crate motor.with heddman headers.this worked out well with the toyota power steering gear box.only had to raise the motor a 1/2" to clear a fitting. Up graded the kit from c c p and that was a piece of cake. I have some pictures soon.
    bobby
  6. Bobby 57
    Bobby 57 Member
    Long Beach Ca
    I need to hire a proof reader. missed some info on my last post.the ccp upgrade was the disc brake package with vacuum assist on the original front axle
  7. steve
    steve Member
    Virginia
    The dis breaks kit was from out host? Works on 16 inch rims?
  8. Bobby 57
    Bobby 57 Member
    Long Beach Ca
    Im using 8x15 rallye style wheels with plenty of clearance. the rotors work with the existing hub assembly with an upgrade on the wheel bearings.I believe the rotors are 11" or 12" in diameter.
  9. Bobby 57
    Bobby 57 Member
    Long Beach Ca
    I did look at the kit our host has and it appears the same or very simular kit
