Swapping a 1970 3/4 ton rear end
Discussion in '1967-1972' started by 70 Chevy, Jun 26, 2006.
  1. 70 Chevy
    70 Chevy Member
    Right now I have a 1970 Chevy CST 3/4 ton pickup that had a 350 engine and I swapped it to a 1977 350 Monte Carlo engine and auto tranny. Right now I have a heavy duty 8-lug rear end and want to change it to a higher gear 5-lug rear end the easiest possible way that doesn't involve a lot of messing around like if theres one you can just bolt right in. If anybody knows what kind of rear end would go best or what it takes to do a rear end job, any advice or comments would be appreciated.
  2. dvalentine
    RE: Swapping a 1970 3/4 ton rear en
    Your path of last resistance would be to use a 68 - 72 rear. Those are 6 X 5 1/2 lugs. Replacing the axles with 5 lugs from places like Mosler will get you a bolt-up 5 lug rear with no welding required.
    Sorry this took so long to answer. I havn't stopped into this forum in a while.
    DVal
