switches to just run the motor temp
Discussion in 'General Chevy & GMC Pickups Talk' started by tri5283, Mar 30, 2005.
  1. tri5283
    tri5283 Member
    fountain inn usa
    I just rebuilt my 283 and wanna crank it occosionally to keep it loose. Its in tha frame on blocks ,hooked up to the tranny & rear end. How can I make a switch to do this ? Gonna take a while on " the other things" before it goes on the road. The old wires are pretty shot, but will work today haha. I plan on a new wiring kit later ,after, other priorty cost. Anyone got an "ideal" ? :)
  2. dvalentine
    RE: switches to just run the motor
    Easy. Get an oil pump primer and pump oil through the oil galleries every two or three weeks. Pull the plugs out and turn over the crank by hand with a breaker bar on the crank pully every two or three weeks.
    To prevent condensation inside, stuff paper towels in every opening on the motor. Exhaust, etc. Cover the carb with a CLEAN shop rag and place the air cleaner on top.
    DV
  3. towman1970
    towman1970 Member
    marquette united states
    you can get a switch that hooks to the starter mechanics use to bump the motor you can find it at local parts store just ask for a push button switch for the atarter they should know what ur talking about. good luck
    thers no man like the towman
