Tail ligh and stop light help
Discussion in '1960-1966' started by ronthet, Oct 18, 2002.
  1. ronthet
    ronthet Member
    Flower Mound USA
    Wiring problem. Have determined the following. 66 chevy truck with 327 in it. I have the factory tail light that worked with turn and park, but not stop. I have other stop light I want to do away and make the factory work.
    Found 4 wire together from the front and they run the following.
    Yellow - Left turn
    Dark Green - Right turn
    Brown - tail light
    light green appears to be dead
    Red - new wire (single) is stop light.
    My factory light has
    Left side 2 brown and 1 yellow. I know the yellow is to yellow and the brown is to the brown for tail light and the other brown goes to license plate blub.
    Right side has 1 brown and 1 green. Green to green from front and brown to brown for tail light.
    Ok how do I get the stop light wired back in?
    we tried to put the brown and red together but did not work.
    any help would be appreciated. thanks
  2. evers310
    evers310 Member
    Atlanta USA
    This link should help you out:
    http://pages.zdnet.com/64moneypit/60to66chevytrucks/id12.html
    One thing to remember, the 2 row, 1/4 moon connector that goes to your steering collumn has to be hooked up for the brake lights to work.
    '66 C10 Fleetside LWB 350/350
