th350 on a 96'
Discussion in '1973-1987' started by punisher 74', Apr 20, 2010.
  1. punisher 74'
    punisher 74' Member
    kcmo
    howdy, well i have a good th350 that s laying around and my gpa has a 96' with a bad tranny. so my ? is will that th350 fit his 96' and how hard will this be?
  2. nerfherder78
    nerfherder78 Member
    Fairfield, CA
    It would probably be much easier to just replace/rebuild the current trans in the truck.
    The way the newer auto transmissions (4L60e and 4L80e) is completely different from the th350 and may require changing/reprogramming the computer. You would also need to look at the driveshaft length, crossmember, and how the shift linkage is hooked up. None of these are insurmountable, but they may make it more trouble than its worth.
  3. punisher 74'
    punisher 74' Member
    kcmo
    thanx
    yeah i was thinking it had a 700r on it but its got the 40. i was just trying to save the old man some bucks. thanx for the reply
