The heater leaks cooling water
Discussion in '1947-1954' started by wokri, Mar 19, 2014.
  1. wokri
    wokri Member
    Germany
    Hello guys,
    the heater of my truck leaks cooling water. Do you a dealer where get buy a new one, which fits in my truck build 1953.
    Ask
    Wolfgang
  2. DeadZoneTruckin
    DeadZoneTruckin Member
  3. skalywag
    skalywag Member
    Nashville
    Guten Tag,
    If it is a "Donut" core, you may want to check with Maine Radiator. They provided me with one that is performing perfectly.
    I am running a 0 psig radiator cap and the cooling system is functioning very well. <180 degrees F.
    This is for a 1953 1/2 ton with a 1960 235 engine.
  4. wokri
    wokri Member
    Germany
    Hello and Guten Tag,
    I took a photo from my heater inside the cab. And I think the water comes out of one of the tubes where the hoses will be connected from the water pump.
    The heater which is in my truck is surely not original. Look at the photo.
    Wolfgang
  5. Chiro
    Chiro Member
    heater
    Doesn't look like either of the two heaters that I am familiar with that came with these trucks. Best bet would probably be to pull it and disassemble then bring the core to a radiator shop to match it up or repair it. If there are numbers on the core that might help or if there are numbers or brand name on the heater box that may help too.
    Andy
  6. Tubby
    Tubby Member
  7. Blueflame236
    Blueflame236 Member
    Norway
    Heater rep.
    Hey Wolfgang
    if Your pleased with the one you have i would suggest to remove the heater and open it up and see inside whats wrong with it. If your heater core is toasted its fully posseble to replace it or have the brass tube fixed. But maybe you would want a time right complete unit that fits the year of the truck ? You could place an ad here at the Chevy forum and see if there are some for sale , or using other Sources to find one !
    Martinius.
  8. 1951chevy1ton
    1951chevy1ton Member
    Near Sleepy Eye MN
    Leaking Heater
    Besides a leaking core, it is a possibility that the brass Inlet and or outlet tube has been crushed from over tightening of the hose clamp. It was on mine and it is repairable.
    Jerry
  9. wokri
    wokri Member
    Germany
    Hello,
    the heater is repaired. I cut of the two brass tubes from the radiator and solder on it new copper tubes.
    It wasn't hard to repair the heater.:D
    Wolfgang
