Time to re-torque
Discussion in '1947-1954' started by Bill Hanlon, Dec 30, 2013.
  1. Bill Hanlon
    Morris Ranch TX
    I have about 200 miles on my GMC 228 valve job and think it is time to re-torque the head bolts and set the valve clearance again. I know I am supposed to set the valves hot. Does it make any difference if the head bolts are torqued hot or cold?
    Santa brought me a new torque wrench (the old one intermittently didn't "click" although was very accurate when it did) and I have the special 3/4" wrench.[​IMG]
  2. Bilbo
    Bilbo Member
    Magnolia, Texas
    I received a new torque wrench for Christmas too. Will need it when I replace the rear main seal. I'm pretty sure the head bolts get torqued cold. Just like when you install the head.
    I would have jumped at the chance to go 'inspect' a truck with you if I had been available, Bill. Take Care.
  3. Bill Hanlon
    Morris Ranch TX
    Any time line on the door latches??
  4. Bilbo
    Bilbo Member
    Magnolia, Texas
    Gonna' try and get them done before Jan. 27th, as that's the day I get a new left knee. I suspect it will be difficult to work on the truck for a while after that. I want to do the rear main seal first, as I'm not looking forward to that job, and want to get it out of the way first.:rolleyes: Mayhaps the week of Jan 13th?
  5. Bill Hanlon
    Morris Ranch TX
    Just give me a little notice. I'm plan to use your truck as a learning session, then do mine.
  6. ol' chebby
    You two order together, I might be able to save some on shipping......I'll have to call.
  7. Bilbo
    Bilbo Member
    Magnolia, Texas
    Will let you know when I think I'm gonna' start, Bill.
    Russ, I've already got my latches.... from You ;) (Bill Brubaker) A couple of weeks ago. Thanks.
  8. vwnate1
    Re Torquing Head Bolts
    Or any other bolts for that matter ! .
    Always do them DEAD COLD , then warm it up and re check & adjust the valves .
    I just bought a brandy new Proto Torque Wrench , no more Chinese crap for me .
  9. ol' chebby
    Oh, yeah......sometimers is kicking in.
  10. Bilbo
    Bilbo Member
    Magnolia, Texas
    Hey Bill, Do you have the torque specs for the head, main bearings, and rod bearings for the 235? I'll be needing to do some of that myself soon.
    Side Bar: How often do you need to add a little water to a typical non-pressurized system like ours? I put a recovery tank on mine, and it seems to almost always be empty. I put just enough in it cold to see a level, (about an inch) and when it comes up to temperature it mostly fills up the tank. After cooling, it's empty again. I've always had a full radiator when I check it though, so Maybe I just need to leave it alone...
  11. SinclairChevy
    SinclairChevy Member
    Keokuk, Iowa
  12. Bill Hanlon
    Morris Ranch TX
    Sorry Bill, all I have is GMC specs. I'll bet Ken can point you to an online Chevy Shop Manual.
    My system is running a 7 pound cap with a recovery bottle. I have about an inch of coolant in the bottle when cold. The bottle fills about 4 inches when hot, then siphons back down to about an inch as the engine cools off. I don't need to add coolant.
