Torque Specs
Discussion in '1973-1987' started by greenizgd, Nov 23, 2003.
  1. greenizgd
    greenizgd Member
    Does anyone know what the torque specs are for the U-bolts that attach the rear axle to the leaf springs. In my auto manual...it says to tighten U-bolts to the specified torque. Usually the listings are in the beginning of the section, but I couldn't find anything about the rear axle U-bolts.
    If anyone could tell me, that would be great. Or if you can direct me to a site that has all the torque specs, that would be even better.
    Thanks for the help
  2. nerfherder78
    nerfherder78 Member
    Fairfield, CA
    found this in chilton's manual under leaf spring removal and installation: 'the following torques are necessary: U-bolts to 150 ft. lbs., spring shackle 50 ft. lbs., front eye bolt 90 ft. lbs, rear eye bolt 50 ft. lbs.' hope this helps.
    Craig
