Is it safe ??? If you get the front end aligned to the new ride hight it should not be a safety issue. Is it comfortable ?? probably not very, but it looks cool ! Val
I turned the screws down until I had 1 inch to the snubber. It rides as good as ever and would look pretty cool, if the rear end wasn't up in the sky. Although I never had it aligned, it doesn't seem to show any abnormal tire wear.
You guys just use the original torsion bars? Mine were sagging almost as low as you guys set yours (before I deconstructed the truck) and I wanted to replace them with fresh ones. Any idea where I could get a set? -glaser06
