I'm running a TPI setup on my truck, noticed that at stop signs or lights the engine surges. It gets so bad at times I have to struggle to keep the brakes depressed to keep it from launching into on coming traffic. Any ideas what's going on?
Robert, After remembering you had that nice looking V8 under the hood, I found the link below not sure if it is what you are having or not but sounded as if it was. Hope it helps. http://www.thirdgen.org/techboard/diy-prom/310130-how-fix-some-those.html http://forums.corvetteforum.com/c4-tech-performance/2546700-idle-surging-89-tpi.htm Charles
The Basics ! First thing , replace the fuel filter , then you might try adjusting the TPS . I used to work on older F.I. systems and this was a problem back then too .
Robert, like it or not, you have a HOT ROD pickup! What, you expect it to wait patiently for the light to turn green??? You built that monster, now you'll have to deal with it!
