tranny
Discussion in '1960-1966' started by old chevytruck, Jan 13, 2010.
  1. old chevytruck
    old chevytruck Member
    does anyone know where i can find a flat floor for a automatic instead of the 4 speed hump?
  2. 2tons of fun
    2tons of fun Member
    ninja town
    you cant, it still sticks up some.
  3. willz66
    willz66 Member
    Bakersfield,California
    or if u have sumone rebuild that lil section fur U,,,thats kinda 'sum work' tho,,if u wanna 'go that route' u keep'n the stock bench or go'n with buckets?:confused:
  4. bigtimjamestown
    bigtimjamestown Member
    Jamestown Ca.
    You can't. I went through this myself, The cab is different for a automatic than a 4 Spd. The fire wall is designed a little different for the automatics and the two different covers will not interchange.
  5. 66 KUSTOM
    66 KUSTOM Member
    SALEM OR
    i flatened the hole then welded in sheet metal. a little grinding, primer and paint, looks like one solid peice now, cant tell there was ever a hole there.
    took me about an hour.
