Transfer Case ID - identification P
Discussion in '1973-1987' started by Zeitgeist57, Nov 20, 2005.
  1. Zeitgeist57
    Zeitgeist57 Member
    Naples
    Hey guys!
    After moving from Ohio to Florida (great move:7 ) I purchased a 1967 Jeepster Commando for a beach-bum ride on the weekends. Picked it up in Miami and it needed some work, but it's stone simple and I'm looking forward to fixing it up.
    I need help...the stock 225 odd-fire V6 was yanked and a 4.3L Chevy V6 (700cfm Double Pumper Holley 4BBL, Mallory Uni-Fire ignition) was put in. It's running very rich but I got it to idle yesterday...still needs a rebuild/cleaning. It's also got a TH350 auto that in yesterday's drive down the street shifted into second gear very crisply. So I've got that going for me...:)
    LASTLY...I am trying to identify the transfer case. There is what looks like a logo with an "NP" inside a gear. I'm guessing (also since it's bolted to the TH350) that it's an NP203 or NP205, but I wanted to get a little help. Here are some of the case marks:
    BY THE TRANNY INPUT YOKE and FRONT DRIVE YOKE:
    AY 4
    C 11483
    BY THE REAR OUTPUT YOKE:
    U
    C-11890
    10-20-75 (casting date?)
    Also, the shifter is a twist-shaft that accepts a keyed plate. Please help, because it's throwing a ton of oil out the output shaft. Thanks! :)
  2. 81 BLAZER
    81 BLAZER Member
    RE: Transfer Case ID - identificati
    is it tranny fluid or gear oil? what is the shift pattern for your T-case? if it goes like this from the seat twords the dash 4h 2h n 4l then you got an np205... and if that is the case and you are leaking tranny fluid it could be one of two things! one you could have a leak in the seal between the tranny and the T-case... other may be that some one just put the tranny fluid in the T-case instead of gear oil. or you may just have a bad seal in your output shaft...
  3. pacrat1967
    pacrat1967 Member
    waterville u.s.a.
    a 205 is gear to gear, all cast iron. a 203 is chain driven and is also cast iron,but the 203 has an aluminum tail shaft housing.the 205 was put behind 4 speeds while the 203 was put behind autos and unless its been converted,its full time 4wd.my 82 blazer has a 208 which is a aluminum case.
