Truck bogs down when I accelerate...
Discussion in '1973-1987' started by taylormade85k10, Jul 27, 2007.
  1. taylormade85k10
    taylormade85k10 Member
    My 85 ( K10 305 auto trans ) truck bogs down when I accelerate...I can back out of the gas and it seems like the further I back ou the more speed I pick up ( no really it does ) ... If I pull the thing down in 1st and shift through the gears it accelerates just fine...is it the trans or carb ??? :confused:
  2. drabo
    drabo Member
    Patrick AFB, Florida
    Could be air/fuel mix, timming, timming advance. Use a timming light to see if the timing advances when you give it gas.
  3. frikenwoodro
    frikenwoodro Member
    my truck does it too but its fuel injected so how would that be fixed?
  4. William Wyatt
    William Wyatt Member
    N.C.
    One other thing you may want to check, is your Cat Converter. It may be starting to get clogged up.
  5. sargechevytruck
    sargechevytruck Member
    when the truck boggs down like that if its carberated its usually the accelerater pump. you can get a rebuild kit and a book to rebuild it. if its stock you should have a quadrajet carb. as for fuel injection u might want to have the throttle position sensor tested. Hope this helps.
  6. stratomaniac
    stratomaniac Member
    might wanna check the vac line to your timing advance, could be cracked or off. My advance unit got cruddied up and stuck and did the same thing...like drabo sez, make sure your timing advances when you give 'er gas.
