truck dies when given any accelerat
Discussion in '1973-1987' started by crazyt95, Feb 2, 2006.
  1. crazyt95
    crazyt95 Member
    Joplin
    My 87 silverado died last night going down the street. I could get it to start back, but when i would give it any gas it would die. Had Autozone check the coil and the distributor module this morning. The coil was good and the module was bad so I changed it. There is power getting to the coil but it doesn't have any spark. Anyone have any ideas on what might be wrong?
  2. trkupdvr
    trkupdvr Member
    Georgetown USA
    RE: truck dies when given any accel
    My '77 did the same thing. I also went to Autozone and did the same as you. Believe it or not it wes the fuel filter. After I change it out it ran great. :) Hope this helps
  3. 86badboy
    86badboy Member
    morrisonville usa
    the only thing autozone knows what to do is look up the part numbers n get it off the shelf they r pretty much worthless when it comes to finding ur problem
  4. Old77
    Old77 Member
    Lee's Summit
    This has also happened to me in my 77 and it was a carb problem. Just needed to be "tuned" better. So a twist of the screw there and twist of a screw over here and there she goes:)
