Truck starting with exhaust smoke
Discussion in '1973-1987' started by ryanova, Apr 8, 2005.
  1. ryanova
    ryanova Member
    Does anyone have any suggestions on what I should do? Whenever I start my 87 Chevy a big puff of black smoke comes out of the exhaust and then it doesnt do it anymore. What do I need?
  2. eugene68
    eugene68 Member
    phoenix u.s.
    RE: Truck starting with exhaust smo
    if it is a black puff of smoke that would indicate that your engine is starting rich.. if running carb, check for stuck choke or overrich settings.. if running fuel injection,start with changing your oxygen sensor.
    good luck hope this helps.
    eugene
  3. Eric87Chevy
    Eric87Chevy Member
    Baytown USA
    O Rings could be leakin a little oil which causes it to blow the smoke. Nothing major if that's the case. Black smoke is usually oil burning. my dad had an 89, and it did this, and the engine ran forever. The smoke was only when it started. Hope that helps
  4. eugene68
    eugene68 Member
    phoenix u.s.
    I was always told
    black smoke was an overrich condition,(too much fuel or incomplete ignition)
    blue smoke was an oil burning conditon ( indicated poor oil control either in worn valve guides or piston rings)
    white smoke was an indication of blown head gaskets or on rare conditions, burning brake fluid. VERY RARE.
    anyone out there know if this is correct? or hear different? please correct me if I am wrong.
    eugene.
  5. Eric87Chevy
    Eric87Chevy Member
    Baytown USA
    your right about the smoke thing, but sometimes it's hard for people to see the difference in Blue and black smoke. If you dont look right at the smoke when you start you might think that it's black when it's really blue. But you are right.
  6. 85Silverado
    85Silverado Member
    Couldn't the white smoke also just be condensation from being in the cold overnight?
    Something like that - then when you start it up, BAM, it burns up and runs fine the rest of the day.
    That's what I heard
    http://my85silverado.tripod.com/
  7. taylormade85k10
    taylormade85k10 Member
    I have a factory q-jet on my 85 K10...can I adjust the carb using the two screws at the front of the carb ? Or are they set at the factory and can't be adjusted ? If they can be adjusted , what is a good starting point , ie .. all the in and backed out 1/2 turn ?
    Thanks for any help
  8. 81 BLAZER
    81 BLAZER Member
    Blue smoke on start up = valve guid seals, (standard chev sb problem) But this won't hurt anything... and black smoke as stated above is a rich running condition which is also known as carbon build up. The screws on the carb are an Idle mixture screw and probably won't help much I would suggest checking the choke, then jets and needles.
  9. 87gmc4x4
    87gmc4x4 Member
    it might be your valve seals
  10. Pontiac1976
    Pontiac1976 Member
    Ontario, Canada
    If it fuelinjection time run the codes. check the sensors.
    Black smoke most time is rich & blue is oil . As stated above problems
  11. dane st. cyr
    dane st. cyr Member
    Louisiana
    if its carbureted. take the carb apart and tap lightly on the lead plugs on the botton of bowl to reseal the bowl, there are two
  12. Guam52
    Guam52 Member
    Virginia
    I had the same problem on my 1987 4x4 replaced the valve seals and the problem went away.
  13. Pontiac1976
    Pontiac1976 Member
    Ontario, Canada
    Well if it more of a blue then yes the vales seal would be time to change, if the still the untouched 87 factory one in there. Most like leaking a little by now. ( or the valves guides need re-done at a shop or buy new heads)
    Not to hard to do valves seals if you know how to do it & have tools to help.
