Trying to keep my cool
Discussion in '1947-1954' started by mobileortho, Jul 7, 2008.
  1. mobileortho
    mobileortho Member
    Hampton, VA
    I mounted the dryer and condensor on my truck over the weekend and have gotten to the point where I'm deciding on the best way to keep it cool. As I mentioned in a previous post, I was contemplating using the Taurus fan. The truck came with an 11" electric unit that I mounted to the condensor. My question is do you think the two would fans work together ok(Tarus unit mounted to the radiator - puller, 11" mounted to the condensor - pusher)?
    Rob
  2. ol' chebby
    You can mount them both , using the 11" as a dedicated a/c fan.
    Rob ;
    If you mount the AC condensor 3/4" away from the radiator instead of flat up against it , it'll be way more efficient .....
    Use the largest fan you can fit .
