I knew there would be some fabricating to be done when I started replacing fenders but with all my pictures I'm still stumped. You guys with a SBC 350, how did you fit your inner fenders to fit around all that new stuff you have? Remember a picture is worth a thousand words. Thanks
The 350 shouldn't interfere with the sheetmetal. I had to notch over the fatman upper mopunts, but that was all.
You shouldn't have any problem with the sheet metal. The original gearbox would be the only problem I know of and if you've done a steering conversion, then all should hook up just fine. You can look at my project journal. There are a lot of pictures. http://www.hotrodders.com/forum/journal.php?action=view&journalid=25573&page=11&perpage=5&reverse=
1inxs You have the original front axle, mine is a MII and probably I'll need to notch for the uppers.
Put the radiator support on the frame and try a test fit. Odds are you'll need to trim a little bit of the inner panel to clear the upper A's but it should be minimal. When I helped Boop's Dad hang his fenders and hood last year, we had to nibble away on the panels. Boop's truck has a camaro clip and V8. Good luck.
