1964swb
Guest
I am working on a 72 C10 with a 307/350 turbo combination. It seems to leak a bunch of transmission fluid after setting for a period of time. It had no sign of front or rear seal leakage, so I replaced the filter and pan gasket and then test drove it for several days. No leaks! After setting for a month or so, it had another big puddle of ATF under the truck. Hard to tell where it is coming from (closer to the front of the transmission than the rear, judging by the puddle).
When I checked the transmission fluid level after this last big leak, it showed way OVER full! I know the fluid level was right on when I replaced the filter. Once I started the engine and shifted the transmission, the fluid level was barely on the dipstick. What gives? What is causing this crazy intermitant leak?
