Turbo Charging a 292 cu inch 6
Discussion in 'Performance, Engine, and Transmission' started by fasted, Aug 9, 2009.
  1. fasted
    fasted Member
    Any advise for turbocharging a stock low mileage 292 cu. inch 6 cylinder. I would like to use a draw throught system with about 6 lbs of boost.
  2. dvalentine
    Common ??? Nobody ??? I was hoping this one would get some interesting information...
    dv
  3. Hotrodkilroy
    Hotrodkilroy Member
    Wilton,Maine
    yes i info in book on rodding 6 cyl elderbrock makes aplication for six banger hangs off the side im sure its not much differant set up than a V8 kilroy was here
  4. fasted
    fasted Member
    Thank you,
    fasted
  5. vwnate1
    Didja ever do this ? .
    the 292 is a long stroke engine and so isn't a good bet for a puffer .
    I'm just curious how it worked out .
  6. 66 Truck Drive
    66 Truck Drive Member
    Next to my bench at the shop, Oregon
    The 292 can be turbo charged to 10 pounds of boost stock. 8 pounds of boost is better cause you can be meaner with it, and not worry about a blow out. The inline 6 comes with 7 main bearings....so they have a tough bottom end!
