HI, i have a 96 gmc yukon and my turn signal switch ,i thought didnt work so i replaced it with a new one,and it still does the same thing, nothing, i have no turn signal's and no emergency flashers,i need help any ideas.
The fuses or the flasher relay chech there by the box to the place where you pluged in the wireing for the turn single.Then check the light sockets for bad bulbs & ground or postive.
turn signals HELP, I.m puting new gauges and replacing the old cluster.I,d like to know how to hook up new blinker lights.I,m using auto meter gauge,s.I will be replacimg the speedo also.In replacing the old cluster I also will not need the cluster wireing so I will try to use new signal bulbs.I have a 1966 gmc stock sterring column,No tilt or shift lever.
