Lakeroadster
I posted this data in my build thread and thought it might be worthy of its own post. My truck is a 1965 SWB C10. I am pretty sure this modification will also work on 67-72's.
Because the rear of the truck has been lowered 5” the rear shocks are inclined about 40 degrees. Therefore they need to be repositioned so the shocks are more vertical.
Upper Shock Brackets:
I designed some new upper shock brackets to accomplish this. The new brackets replace the stock upper mounts and bolt to the frame using the rivet holes from the original stock upper mount. (Per Monroe, shocks cannot be angled more than 30 degrees. If they are more than 30 degrees they may tend to have lapses in dampening.)
Rear Shock Brackets:
The stock lower shock mounts on the 63-66 coil spring trucks are far superior to aftermarket mounts. The stock mounts are a heavy steel stamped part that captures the shock on both sides. Supporting on both sides makes a huge difference in the brackets strength and ability to properly load the shock. There is simply no need to replace the stock mounts. The replacement mounts that are being sold capture the shock on one side only. If you are replacing the lower mount with one of these aftermarket brackets you are replacing a strong part with a weaker one. Based on the numbers I have crunched the stock lower shock mount is twice as strong as the aftermarket ones.
The stock shocks were bottoming out when I bought the truck. I did some research on Monroe Shock Absorbers website http://www.monroe.com/catalog/miscApplicati ons.asp . They have a pdf entitled “Mounting and Length Sheets” that lists all their shocks and includes mounting configurations and lengths. Using this data and the dimensions of my new set-up I selected Monroe shocks 32207. These have an Extended length of 17-7/8”, and a collapsed length of 11-1/4”. These shocks were originally used on ½ ton Ford trucks and therefore the valving will be correct. With my rear spring and custom snubber set-up the shock length = 11-3/4” with the rear axle against the snubbers. Therefore the shocks won’t bottom out before the snubbers engage. Ride height shock length = 14-1/4”.
Stock Upper Mount
To remove the stock rivets I drilled a 3/8” hole in the center of each rivet.
Then used a chisel to shear the head off the rivet
Here is the new bracket I designed and fabricated above the stock bracket
New bracket moves the top of the shock back about 4 inches
And up a little over an inch
[/INDENT]
Stock Upper Mount
