What is the best way to put on front fenders
Discussion in '1947-1954' started by jason6101188, Jan 4, 2007.
  1. jason6101188
    jason6101188 Member
    g5riffith US
    What is the best way to put on the front fenders on my 50 gmc I was thinking to bolt the inner fender to the fender and then bolting the inner fender to the truck. Plus i got the inner fenders painted and the edge of the fenders painted so i want to put them on carefully so i didn't scratch the paint. And then i got the peice on the gmcs that bolt to the front fenders.
  2. Kens 50 PU
    Jason, either way is acceptable. Remember to put the anti-squeak on the inner fender first. Do you have a copy of a shop manual? It gives you a pretty good idea of how to do it. If you don't, go to www.chevy.tocmp.com and look at the 48-51 chevrolet shop manual, section 11, and it will give you some good ideas. Also, get you some masking tape, and tape all of the parts that you plan to assemble that might get scratched up, tape them, then assemble loosely, and when you get ready to put the final twist on the bolt, remove the tape, and viola, no scratches.
  3. Kevin's 48
    Kevin's 48 Member
    Tn
    Use painters tape if you use any tape at all so that it doesn't leave any nasty residues plus it sticks a little better.
  4. Larrys 48
    Larrys 48 Member
    Spokane, WA
    Anti-squeek!
  5. Kens 50 PU
    Larry, the anti-squeek is the kit that goes in between the inner fender panels and the fenders. All vendors have them. The fender welt goes between the fender and cab. The original anti-squeek was held on by staples. Modern methods (if you want to cheat) include a general adhesive.
    Also known as inner fender seals www.classicparts.com/prodinfo.asp?number=37-725
  6. ol' chebby
    I have found that the bolts i took off usually work pretty well to put them back on.......
  7. vwnate1
    OnLine Chevy Manuals
    Here's the new address , that old link is dead .
    http://chevy.tocmp.com/
    It's a pretty good resource .
