what is the curb weight of an 83 C10 SWB?
Discussion in '1973-1987' started by jdwestsr, Dec 21, 2007.
  1. jdwestsr
    jdwestsr Member
    I can't seem to find any reliable information on the actual weight of a 1983 C10 Silverado. I need to tow this truck and want to be sure I am not overloading the tow vehicle. Any help would be appreciated.
  2. Pontiac1976
    Pontiac1976 Member
    Ontario, Canada
    Did you check the glove box to see if it's there or the driver door should be a sticker there in one of those places that has that info. If it's gone then Well it should be less then 5280 lbs that what my 77 2 wheel drive long bed GMC 1/2 Ton with a 9' steel flat bed 81-87 front clip 350 to 400lbs lighter then 73-80, 454 motor 750lbs, 350 motor 550lbs that year should have a 10 bolt diff witch is about 50-80lbs lighter then 12 bolt.
