hope info this helps... 1960 /61 shop manual supplement to the 1960 manual lists the 4 speed transmission as a "4-speed chevrolet code C4". It does however, list the addition of an auxillary 4 speed tranny made by SPICER as the only change to the manual transmission lineup from 1960 This auxillary was used on the model M80 tandem axle trucks. both the 61 / 62 suppliment and the 60 manual have the 4 speed designated as code C4, but not the supplier of the C4. Spicer was the supplier of two of the four 5 speed tranny's listed in 1960 shop manual. Clark was the other. No mention of Muncie. KYCHEVY
[updated:LAST EDITED ON Feb-14-02 AT 00:46 AM (CST)]Hey if you go to www.americanclassic.com and go to the vin decoder and look up trannys for a 62. Hope this helps. this is what i got 1962 Transmission codes Code Series Description Plant C N/A Powerglide Cleveland M N/A 3 Speed Muncie W N/A 3 Speed HD Warner Gear S N/A 3 Speed Commercial Saginaw B N/A Powerglide (Corvair 95) Toledo 1960 Transmission codes Code Series Description Plant W N/A 4 Speed Warner Gear S N/A 3 Speed OD Saginaw H N/A 3 Speed OD Saginaw C N/A Powerglide Cleveland B N/A Turboglide Toledo Cowboy
Im not sure that this is right, but I have a 62 and am pretty sure that it has a Saganah tranny in it. Don't know if that is how to spell it, but its a 4 on the floor with a granny, with reverse towards the driver. Hope that helps a little.
