Wheel cylinder?
Discussion in '1973-1987' started by cj55, Mar 22, 2010.
  1. cj55
    cj55 Member
    Trying to I.D. a rear axle for a 74 Chevy pick-up and whether it is 2WD or 4x4. It is on my 55 chevy truck. The brakes that were on the axle are 2-3/4" wide. The wheel cylinder bore size is 15/16" with the rubber boot on the outside of the bore and the pins have a tapered end. In trying to find replacements, the stores have a 15/16" bore with boot on the inside of the bore. The wheel cylinder for a 2" brake with a 1" bore has the boot on the outside of the cylinder. Which is correct? Help!!!!
  2. Pontiac1976
    Pontiac1976 Member
    Ontario, Canada
    Can you see if there any other info readable on the housing. I know that 75 and up to 77 there could be two different set up dependes on the option they hadon it. It is a 12 bolt right?
  3. cj55
    cj55 Member
    It is a 12-bolt. I cannot find any other id marks on it. I have tried finding them before - no luck. The axle has been painted with POR-15. Would it be ok to use 1" bore cylinders with 2-3/4" brakes?
